800mhz in a 1066mhz/1333mhz mobo
Aug 30, 2018
So I was looking to buy a new motherboard and transfer as many components from my old build as possible. I have 2 4gb 800mhz RAM sticks and I was wondering if they would be compatible in a motherboard that states it's supports 1066/1333 RAM.
Aug 30, 2018
Cpu: i5 3570k
Gpu: R9 270
Psu: 500w corsair
RAM: 2x 4gb 800mhz
Mobo: undecided but probably Intel DQ67OW
k1114
Is that ddr2? Because ddr2 being 800 is common but not ddr3. Even the first cpus to have ddr3 were 1066. I've never even seen 800 ddr3 ram. You could also be confusing actual vs effective speed. 800x2 is 1600 which is the stock speed for that cpu and common.
Exactly what hardware (and motherboard) are you upgrading the system from, and what are your intentions behind upgrading?
