80mm Fans -- Annoying
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Ok, my computers are LOUD. I hate fans because they make too much noise.
Right now I have two 80mm Sunon fans in each of my two computers, and I feel
like I'm sitting in the back of a 747 when they are both on. I'm thinking
about replacing them with one quiet 80mm fan. I'm also considering changing
the ATX power supplies to a quiet power supply.
It seems like most of the cooling news groups are full of *fan*atics, so all
I'm seeing are posts recommending at least 8 to 15 fans per box -- can we
get some honest opinions on whether or not a standard PC really needs all
this airflow?
Will my machines *really* suffer from just one 80mm fan? I have standard
mid-tower cases... do I really need *two* 80mm fans?
I also see new Dell's more powerful than my PC coming with only one fan.
Thoughts?
YOu can get away with just one. Make it an intake fan at the front of
the case, and (hopefully) your PSU will include its own dual-exhaust
fans moving the air out of your case. You will get half-decent airflow.
I am saying I have 8 fans and my case is super quite. I don't see how your
annoyed by just 2. I have my case up on my desk and right next to my ear.
"Duct tape is a lot like the Force. It has a Dark side, a Light side, and it
holds all the pieces of the Universe together"
"Brent Wege" <brentwege@hotmail.com> wrote in message
news:RAvzc.24720$Hg2.22255@attbi_s04...
feel
changing
all
> this airflow?
> Thoughts?
On Tue, 15 Jun 2004 05:14:25 GMT, "Brent Wege" <brentwege@hotmail.com>
>this airflow?
>Thoughts?
http://www.silentpcreview.com/
> this airflow?
No, it doesn't.
One would be enough, depending on what criteria you use to determine 'enough'.
People seem to be terrified of 'heat' and have somehow gotten the idea that
everything should be as near room temperature as possible. Well, that might
be nice but there's the 80-20 rule, which states that the last 20% of
anything takes 80% of the time/cost/resources/what-ever-hurts. E.g. a 6C to
10C case rise can be had with reasonable airflow but it you want it down to
3C it's hurricane time.
You'd have to tell me where your two fans are located. Is that two rear
fans or one front and one rear? If it's the later, you can probably
eliminate the front fan with little impact, unless it's located in front of
the drives, in which case a low speed, and quiet, fan would do nicely
(although you could still probably eliminate it).
Odds are the rear fan is overpowered, if your complaint about noise isn't
exaggerated.
But it depends on the case layout and a host of other factors (like, is it
perforated with holes all over the place?). There isn't a 'simple'
solution. Well, except for the "hoot, man, throw another fan at it."
Note, front fans sound louder because... they're on the front and closer to
your ears. They also have the least impact on case cooling (as they're
typically used home-built PCs) so reducing the speed on those, or
eliminating them, has the most impact on noise with the least impact on
cooling.
Second note, most case 'fan vents' stink. The stamped (round) hole pattern
is a noise maker and it'll reduce the noise if you cut that out to a full
fan hole pattern and use a wire grill. PLUS, the airflow will go up as
well, (bigger hole = less air resistance) which means a low RPM fan will
move as much, or more, air as as your high RPM screamer trying to push/pull
air through those lousy punched holes.
You could try the '7V trick' on your existing fans to quiet them down and
see how effective they are at the lower CFM.
Dell has the advantage of being able to control the layout of every
component in the system and can optimize the case airflow patterns because
of it. General market case and motherboard manufacturers don't know what
each other, much less the user, is doing and so you end up with 'extra'
effort in places (like a fan on the heatsink).
For an example of how one can 'optimize' things, consider this new solution
from thermaltake
http://www.thermaltake.com/coolers/cl-p0019Fanless103/cl-p0019fanless103.htm
That brings the heat to a radiator that can be cooled by the rear case fan,
in that case a 90mm which can turn slow, quietly, but still move a fair
amount of air. You'll see similar things in Dell cases although they can
avoid the cost of the heatpipe by laying out the motherboard and case so
that a large 'passive' heatsink on the processor lines up with the rear
case fan properly, perhaps with some moderate shrouding to direct the
airflow. And when you control the whole ball of wax you can do even fancier
things with it.
One beautiful example I saw was a Compaq dual P-III work station. Air came
in the front through a cardboard shroud that lead it across the two passive
heatsinks on the dual P-IIIs, was then directed upwards and back to the
front across the motherboard components, then to the rear again across the
hard drives and CD drives, eventually existing out the back. And a low
speed fan to boot. You could hardly tell the thing was on.
Of course, the case, motherboard, PSU, heatsinks, and ducting were all
custom designs that you couldn't duplicate with 'off the shelf' components.
You'd end up with a PSU fan(s), two processor fans, and at least one case fan.
> this airflow?
Get one or two PC Power & Cooling Silencer 80mm fans.
At 20dBA, you'll barely hear them.
That should be all that you need. 8 to 15 fans per box is completely
ridiculous.
http://pcpowercooling.com/products/cooling/silencerfan/index.htm
-WD
i prefer 3 quiet 80mm case fans (2 front filtered intake and 1 rear exhaust)
plus the PSU fan which is another rear exhaust. this creates slightly
positive pressure so you're not drawing in dust through your drives or
anywhere else.
i used panaflo L1As mounted with EAR fan isolators which are very quiet and
what sound they do make isn't an annoying type but if i were going to build
today i'd probably use the nexus real silent fans even though they won't
work with the fan isolators because these fans have solid corners.
feel
changing
all
> this airflow?
> Thoughts?
"David Besack" <daveREMOVEbesack@mac.com> wrote in message
news:cam1a3$foir$1@netnews.upenn.edu...
standard
I agree with what you wrote. The OP also needs to be aware that one LOUD
fan can easily drown out the noise of several quiet ones. So it's not
necessary to reduce the number of fans. If you want quiet, you simply need
quiet fans. But you are right, the OP could probably get away with just
one. I've got two (not counting the power supply or CPU), but my mid-tower
sits inside a desk, so it's already got bad ventillation before I even turn
it on. -Dave
feel
changing
all
> this airflow?
Actually, fewer smaller fans are always going to be much louder than more
larger fans, assuming each move the same amount of air. What you want is
maybe one 120mm fan. But if you're not overclocking 1 fan should be OK
(assuming the power supply also has a fan.) But search for quiter, larger
fans, not more smaller ones. See www.silentpcreview.com ,e.g.
> this airflow?
> Thoughts?
The front fan (I assume it's one at the front and one at the back) is
probably the one producing the most noticeable noise for you. That said,
you may wish to replace both (or at least the front one) with quietter
fans. I like the Vantec Stealth fans and use them in my systems.
remove the underscores to unmung the email address...
> your annoyed by just 2. I have my case up on my desk and right next
> to my ear.
I bet you're not using Sunon fans though ;o)
>Thoughts?
Depending on how you're cooling other components, one fan plus the PSU
fan may suffice. Here's what I'm doing:
I've got innovatek water cooling components aimed at my CPU (P4 2.53 @
3.25), GPU (modestly OCed), and hard drive. I picked up two
Noiseblocker S3 80mm fans from whispertec.com. I used one to replace
my PSU fan. I've got the other hanging form rubber bands in mid air
in the open side of my mid tower case blowing on the heat-sinked
graphics card memory and motherboard. I've also got a 120mm Panaflo
medium airflow model blowing through my water-cooling radiator.
Here's the nice part: each of the three fans is on a rheostat allowing
me to vary voltage from 12V down to 3V. Lower voltage = lower RPM =
lower noise. Temps are fine even under load with room temperatures
over 30C ... and I can hear myself think. :7)
George
No I have Aspire Fans. : p
"Apollo" <ian_dunbar6Rém0véMé@hotmail.com> wrote in message
news:2j8pp5Fqjsm1U1@uni-berlin.de...
> > to my ear.
In article <10ct6nu97jij289@corp.supernews.com>, dNOTmayn@ev1.net
says...
> > this airflow?
> No, it doesn't.
> exaggerated.
> cooling.
> is a noise maker and it'll reduce the noise if you cut that out to a fullDell may do a wonderful job of cooling their systems with minimal use of fans. However, the noise that erupts whenever you turn on a Dell was one of the reasons I have chosen never to own one again. The biggest reason is they're terrible tech support, business practice and always somewhat deficient OEM products.
The fan/shroud/heat sink you referred to gave me one of the most
enormous headaches. The fan is mounted in such a way that it cannot be
replaced by a quiet one because it is part of the mounting device. Many
Dell fans become extremely loud after a while. It may be clever
engineering but it is very poorly executed with the cheapest parts
possible.
I much prefer my Antec Sonata case, my Asus motherboard (original and in
the box), my Audigy 2zs card, also in the box, and my ATI card i in the
box. Along with this I have the nexus 120 mm case fan which can easily
be changed at any time.
Louise
In article <40cf1436_2@news1.prserv.net>, nobody@nowhere.com says...
> feel
> changing
> all
> > this airflow?
you might also look at www.endpcnoise.com - they have several systems
available for configuring and all their parts are designed to be very
very quiet.
I just got a system from them which has the 120mm nexus fan, a cpu fan
with fan made at its lowest, and a moderate amount of hardware inside
the case.
I have the Antec Sonata - no front fan but a dust filer, a good cpu fan
(cpu has never been aboute 42c) and one 120mm Nexus case fan in the
back.
Louise
> says...
>>>this airflow?
>>No, it doesn't.
>>exaggerated.
>>cooling.
> possible.
> Louise
The question was how could they do it with one fan and that was what I
answered.
Your opinion about the quality of engineering and cost of parts is an
entirely different matter and, if one judges by sales volume, not
necessarily universally agreed to.
Thanks for all the excellent feedback!
-Brent
feel
changing
all
> this airflow?
> Thoughts?
