ayrton_hall
6
Hello everybody!
I just signed up but i have been looking at Toms Hardwares benchmarks for a couple of years now but never realised that there was an amazing forum :)
I am just about to upgrade my system from an old E5300@3.93GHz as it was just not living up to what I needed it to do. Anyway I am getting a Gigabyte Z68x-UD3h-b3 mobo and a Intel 2500k. I'm not planning on overclocking as soon as I get it but i might over the coming months. But uh oh! I realised that it has a 8Pin power connector for the CPU on the motherboard, and considering i am used to using a single 12V 4Pin for every machine i have built for years now I was wondering what to do. The PSU I am planning on getting is a Akasa 600w PSU: http://www.scan.co.uk/products/600w-akasa-ak-p600ag8-sluk-es-power-supply-psu-with-over-80-effiency
Now considering it has a 1x4pin what should i do in regards to powering my CPU? Do i either put the 4pin into the socket or buy a 8pin adapter? Just remember i do not plan to OC for a while.
Thanks in advance!!
you should postpone purchases Akasa PSU, better look for the best advice for PSU requirements. a lot of really good quality brand Corsair / Anteq /Corsair / Anteq /XFX /OCZ/Be Quite/ Zalman etc .. I think Antec earthwatt 500 W enough and same as price with SAkasa600 but Antec Earthwatt more better efisienci , 4+4 pin +12 volt power cable (no problem .I can not see detail Akasa S600W ( not recommend and No review)
if you've already bought what may make buying the cable as below
4 pin to 8pin
