Question 9070XT Help
Mar 21, 2025
Hey
I recently upgraded from a 3070 to a 9070 XT and have had a lot of issues with games crashing. I've had issues with 'driver timeout' with every game i've played - Avowed, Split Fiction and LoL. Split Fiction has had some incredible issues with aliasing especially in cut scenes, however, LoL is unplayable and will ALWAYS crash. Just sitting AFK in the practice tool will cause a crash in around 20 minutes. I've tried a bunch of stuff I've seen recommended:
  • DDU and re-installed new drivers multiple times
  • Reinstalled with and without Adrenalin software
  • -500MHz max clock in Adrenalin
  • -20% power usage in Adrenalin
  • BIOS update
  • Chipset update
  • Re-seated GPU and RAM
  • Not daisy-chaining PSU connectors
This is a dump from HWINFO. The crash happens at row 1440 where GPU utilization jumps from ~31 to 98.
And another with more frequent logging. The crash happens at row 12602.
Also the logs stop logging for a few of seconds around this time as well. I've run this a many times and it's very consistent. I'm wondering if someone might be able to diagnose anything from these logs.
Specs:
GPU: PowerColor Radeon RX 9070 XT Reaper
CPU: AMD Ryzen 5 5600x
MOBO: Asus TUF Gaming B550-PLUS
PSU: Gigabyte 750W Modular 80+ Gold
RAM: G.Skill Ripjaws V 32GB (2x16GB) 3600MHz CL18 DDR4
Appreciate any help.
BIOS update
For the sake of relevance, please state the BIOS version you're on for your motherboard.
You're advised to remove all GPU drivers(intel, Nvidia and AMD) in Safe Mode, then manually install the latest GPU driver sourced from AMD's support site in an elevated command, i.e, Right click installer>Run as Administrator.
Gigabyte is the brand of the unit, while 750W is the advertised wattage of the unit. Conversely 80+ Gold is the advertised wattage of the unit. What is them model and age of the unit?
BIOS update
Thanks for the response!
The BIOS version is 3611.
DDU was run in safe mode with internet disconnected until the new drivers were installed (except for the time I used the auto-detect driver install). It was run to remove the 3070 Nvidia drivers the first time and has since been run a couple of time to remove existing AMD drivers. I've installed these drivers both from the AMD auto-detect program and also the direct driver file from AMD. I'm actually on the beta drivers now (25.3.2 I believe) just to see if it helps (it doesn't)
PSU model is GP-P750GM bought in December 2020
