$950 Gaming Build - Need advice/opinions
Ashbacher7
134
Here's my AMD Build (in cart on newegg.com)
Case: COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Compucase Case with USB 3.0 and Black Interior
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Motherboard: ASUS M4A88T-V EVO/USB3 AM3 AMD 880G USB 3.0 HDMI ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131668
CPU: AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
GFX: XFX HD-685X-ZNFC Radeon HD 6850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150505
Memory: Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996770
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226095
Hard Drive: Western Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
Power Supply: CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Optical Drive: Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039
OS: Microsoft Windows 7 Home Premium (Comes with Trend Micro Titanium Internet Security)
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116716
Please give your honest advice and opinions! Thanks!
Please don't get a Raidmax power supply as the first post suggest. That's just crazy trusting your near $1000 rig with a crappy power supply. If youre planning a true budget build like $500 or so, AMD is usually the way to go if you want quad cores and decent performance. Anything over $700 is really Intel's territory, you get better performance for your money.
CPU: Intel Core i5-2500k $220
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
CPU Cooler: Stock [Hyper 212+ for $30 or Mugen II for $40 OC if 4+Ghz OC]
MOBO: MSI P67A-G43 (B3) $130 before $20 MIR
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130583
RAM: Kingston HyperX KHX1600C9D3K2/8GX $55 before $15 MIR...
Here is my build I just decided on, I just need to go through the checkout:
$976.35 with shipping:
Core i5 2500k / MSI Motherboard (PCI 2.0 (8x, 8x)) COMBO
http://www.newegg.com/Product/Comb [...] mbo.660242
Asus DVD Burner
http://www.newegg.com/Product/Prod [...] 6827135204
Antec Case
http://www.newegg.com/Product/Prod [...] 6811129066
Samsung HDD
http://www.newegg.com/Product/Prod [...] 6822152185
Rosewill Wireless Adapter
http://www.newegg.com/Product/Prod [...] 6833166056
2x Sapphire Radeon HD 6870
http://www.newegg.com/Product/Prod [...] 6814102948
Antec High Current 750W Power Supply
http://www.newegg.com/Product/Prod [...] 6817371049
G. Skill Ripjaw 4 GB (2x2GB) 1600
http://www.newegg.com/Product/Prod [...] 6820231427
I'm going to have my friend in college get me the "Student" version of Windows 7 for $30. If you or someone you know (anyone) is in college every book store has Windows for a discount.
