I've decided to buy a 21:9 monitor - not the 1440p ones because my GPU would struggle slightly (and dat price doe), but the 2560x1080p versions.
From LG, there's 29in options:
- 95 dots/pixels per inch
- £240
And there's also 34in options:
- 82 dots/pixels per inch
- £400
I have at the moment a 100dpi screen and it's sharpness is fine. My brother has a 95dpi screen and it's sharpness is also fine. So I know the 29in would be okay. But the 34in has nearly 20 less pixels per inch....would this be noticeable? I'm leaning towards yes, it will be. And I can't seem to justify the nearly 2x price range compared to the 29in...the only advantage of the 34in is that it has FreeSync and it's bigger.
Thoughts/advice/experience?
Thanks for all responses
- £240
- £400
