970 Pro Gaming/ Aura Connection Problems
brid108
43
I recently got the 970 Pro Gaming Motherboard. I'm very new to PC building but I followed the manual to the best I can and managed to get the power going and the LEDs on but the monitor says"no signal". The motherboard doesn't have an outlet to a VGA cable. My GPU is the GTX 1050 ti, I have the HDMI cable hooked up but does my monitor need the DVI cable from the GPU?
That CPU is a complete piece of garbage and you shouldn't waste your time with it.
the lower end fx-8300 series CPUs are far better.
Just get a different CPU, not a different mobo.
Also that power supply is a fire hazard.
Yea I was researching more and it turns out that motherboard doesnt support it, a believe it has something to do with the watts. I need a motherboard with AMD 990FX i believe.
