[SOLVED] 9700k temps ok?
Beitzel15
544
9700k, very mild OC, I think it boosts up to 5.1. Running a cooler master 360 liquid cooler in a lian li pc-o11 case.
While running BF2042 for a short time, 30 min or less, my temps are around 70-78C
2080 temps are 58-61C
Am I good with these temps or do I need to look into lowering my cpu?
Hello, those temperatures for your CPU are perfectly safe and the temps for your GPU are really good. CPU's are usually safe until around high 80C's to 90C when it can start to get problematic. At those temps they will run, but may fail quicker than normal, and above 95C consistently the CPU will die much faster, so your temps are perfectly fine.
