Ok...This is a weird one...
I have an older Dell XPS 420. OS is Windows 7 Ultimate 64 bit. CPU is a QX9650 Quadcore @ 3.0ghz, Memory is 8GB. PSU is 500w the biggest Dell offered at the time.
I ran a 9800GTX+ with no issues for 3 years till it kicked the bucket. I am using a HD7570 that a friend gave me.( I can see why).
I need to replace this card, but here are some issues....
1. LCD is a 22inch @ 1680x1050. No plans to go bigger within 2 years.
2. I only have 1 6pin plug. I can not use a dongle adapter because I only have 1 available ide plug and the adapter needs two. I have no available sata power plugs. I have 3 hard drives and two optical drives. The 9800GTX+ drew 145 Watts, so any card that draws 145 watts or less is good.
3. There is only one PCI xpress slot so no SLI or crossfire needed.
4. I play flightsims, Crysis(original), STO, and want a DX11 card
5. I would like to get better performance than what the 9800GTX + did.
6. Used is no issue.....buying on ebay is okay if newegg or tigerdirect does not have anything.
7. Would like to keep cost around 200, new...or 100 used.
Any recommendations???
I have looked at GTX 650 Ti, HD5770 and HD7770. They seem to fit the bill with better performance than the 9800GTX+, and 1 6pin power plug. Any others I am missing???
