980ti or Gsync Monitor as Upgrade?
rabaker07
62
Which would you suggest as a better upgrade, monitor or card?
I currently have:
EVGA GTX 970 SC
BenQ 24" 1920x1200 TN panel monitor
I want to upgrade by getting:
GTX 980 Ti
or
27" Gsync Monitor with 144hz at 2560x1440 pixel resolution - Acer XB270HU or ASUS ROG PG278Q
http://www.amazon.com/PG278Q-27-Inch-Screen-LED-Lit-Monitor/dp/B00MSOND8C
http://www.amazon.com/Acer-XB270HU-bprz-27-inch-Widescreen/dp/B00UPVXDA8
And if the monitor is the way to go, do I wait for the new ASUS IPS? Or will that end up costing $1000+? I'm currently leaning toward either the ASUS or the Acer 27 inch 144hz Gsyncs.
And will I find that with the new monitor, that the GTX 970 won't have quite the horsepower to drive the higher resolution at high/ultra settings and still maintain 60+ frames per second? Vsync is very very very important to me and I will always take lower graphics settings rather than sacrifice anything under solid 60fps. This makes animation look fluid and gives it that real 3d-ish feel.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487141&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Desktop+Graphics+Cards-_-N82E16814487141&gclid=CjwKEAjwiZitBRCy0pb3rIbG9XwSJACmuvvzdPWOO4IgUnJmuXpQbpaxposeopTBXKqOaM6Fv79suxoCaSbw_wcB&gclsrc=aw.ds
**** So which is it? The monitor (and which one), or the new card? ****
Hahah, that's too much money!
I need to pick one. The 980 TI
OR
The 27" WQHD GSync Monitor....
So which should I get between those two to get the biggest upgrade impact? I'm leaning toward the monitor....
