A 1400 MB/s SSD: ASRock's Z97 Extreme6 And Samsung's XP941
aminebouhafs
72
Once an SSD in plugged into the Ultra M.2 slot, the bandwidth between central processing unit and graphics processing unit is cut-down by half. Therefore, while the end-user gets additional SSD performance, the end-user may lose some GPU performance because of insufficient bandwidth between it and the CPU.
Eggz
This makes me excited for X99! With 40 (or more) lanes, of PCI-e (probably more), there will be no need to compromise. We have to remember that the Z97 Chipset is a consumer-grade product, so there almost has to be tradoffs in order to justify stepping up to a high-end platform.
That said, I feel like X99, NVMe, and and M.2 products will coincide nicely with their respective releases dates. Another interesting piece to the puzzle will be DDR4. Will the new storage technology and next-generation CPUs utilize it's speed, or like DD3, will it take several generations for other technologies to catch up to RAM speeds? This is quite an interesting time :)
Damn_Rookie
791
While storage isn't the most important area of computer hardware for me, I always enjoy reading Christopher's articles. Very well written, detail orientated, and above all else, interesting. Thanks!
hotwire_downunder
18
ASRock has come along way, I used them a long time back with disappointing results, but I have started to use them again and have not been disappointed this time around.
Way to turn things around ASRock! Cheap as chips and rock steady!
alidan
Splendid
Aug 5, 2009
5,303
@aminebouhafs if i remember right, didn't toms show how much performance loss there is when you tape gpu cards to emulate having half or even a quarter of the bandwidth? if i remember right back than the difference was only about 12% from 16 lanes down to either 4 or 8
Eggz
PCI-e 3.0 x8 has enough bandwidth for any single card. The only downside to using PCI-e lanes on the SSD applies only to people who want to use multiple GPUs.
Still, though, this is just the mid-range platform anyway. People looking for lots of expansion end up buying the X chipsets rather than the Z chipsets because of the greater expandability. I feel like the complaint is really misplaced for Z chipsets, since they only have 16 PCI-e lanes to begin with.
cryan
106
Well, it'll definitely negate some GPU configurations, same as any PCIe add-in over the CPU's lanes. With so few lanes to work with on Intel's mainstream platforms, butting heads is inevitable.
Regards,
Christopher Ryan
cryan
106
Awww, shucks!
Regards,
Christopher Ryan
obamaliar
28
Supercool review, Just as a note though any pair of good SATA Based SSD's will blow the doors off of that x941. For example I am getting 740.00MB/s bandwidth at steady 5 and 948.37MB/s at recovery 5 for PCM8 extended photoshop heavy from a pair of Intel 730's
obamaliar
28
Evolution2001
110
obamaliar, how do you reckon that your 740MBps or 948MBps is faster than 1400MBps? (referencing the sequential read of the tested drive)
SATA3 has a theoretical max of 6Gbps (750MBps). However, the practical max is more around 600MBps.
Assuming you are running your Intel 730's in RAID-0 and achieving the max practical throughput, you'd still only come up with ~1200MBps which is slower than what Tom's saw at 1400MBps ON A SINGLE DRIVE.
obamaliar
28
Evolution 2001, I am referring to OS simulated performance IE CRYAN's PCMark 8 extended testing. Please read the article and you would understand that sequential performance is really a non-factor in comparison to random performance in an OS environment. Right now, SATA RAID has vastly superior random performance to PCIe drives like the X941, even if you were to soft RAID a pair of X941's together they cannot match a pair of good SATA SSD's in RAID in an OS environment. I cannot show you that exactly because Soft RAID is not bootable. look here: https://www.facebook.com/groups/1445011539065390/ there ia a pair of X941's soft raided getting their asses kicked by SATA RAID. The reason? 4K writes do not scale on PCIe drives. When PCIe drives can be RAIDed, bootable in RAID and have an RST type driver that allows for write caching Then they will become the superior OS disk.
cryan
106
Actually, the 4 KB writes are really an artifact of the AHCI controller/API. If you took the same flash and controller on the Sammy, but rigged it to use NVMe, I think you'd see a big bump in random 4 KB performance. I've said over and over that desktop users, for now, are better off by using a couple SATA drives in RAID. More than just adding bandwidth, which isn't always important (strictly speaking), it lowers service times significantly. Plus, it's great to just keep adding cheap drives and getting more performance and capacity (when striped). See the Plextor M6e PCIe review for my thoughts on this.
It's all academic anyway, since you can only buy the XP941 from a few random places, and it's $750. If I had a laptop which could use it, maybe I go that route, but even there SATA is just more power efficient. Give me a 1 TB EVO or M550 instead..... at least for the time being.
PS: Is this Jon C??
Regards,
Christopher Ryan
Eggz
Totally agree! For now.
I also added the 750 EVO in there because (I believe) the only difference between the 1TB and the 750GB is capacity, unlike the smaller drives, which actually have less performance (i.e. 120, 250, & 500 GB).
