Hi folks
I've just passed my bachelor's degree and want to buy a solid PC to install the following programs.
1 . WAMP (for web based work)
2. JAVA with (net beans, eclipse) IDE's
3. Oracle
4. MS Visual Studio full
5. Adobe Photoshop
6. All of the above one's among other utilities and programs on windows 8.1
Not good in building PC's, wondering which CPU, motherboard and graphic card and how much memory I should buy (by the way I'm not a gamer). So when I looked at the web all I found was a how build a gaming or very cheap and basic PC's. Yes I can play game to get my mind divert some times but do not consider myself a gamer. I want a decent PC that stay stable for another few years.
Therefore I would like to have your advise on this, which CPU I should buy
1. Intel (i7 4790K, i5 4690K)
2. AMD (FX 6300, 8320)
Or any other which you may suggest, as I mentioned Photoshop to be installed on my PC means I only use rarely just to fine twin some images for my free lance stuff.
I've bought a QNIX QX2710 already and fractal design define R4 case, but before I buy the whole system I would like your final opinion on this so I build one that fulfill my needs.
Any advise would be highly appreciated.
EDIT: Budget is around £1000 GBP.
Regards
Usman
3. Oracle
5. Adobe Photoshop
Regards
Usman
