[SOLVED] A dual monitor arm for a 7 inch thick desk
Jun 21, 2020
9
Hey, i have a very thick 7 inch desk, but i cant find any dual monitor arms which fir the size. ideally i want a c-clam style.
Insignia has a large selection of monitor mounts.
However, the max "thickness" I could find was 6 inches.
Is a floor stand mount viable/acceptable?
Google "insignia dual monitor mount floor"
Take a look at the search results then modify the search criteria to narrow down possible product choices.
Insignia or otherwise.
Thanks for the reply. I can't find any ones suitable for my desk but do you know of any dual monitor arms that physically screw down into the desk (not through it like a grommet mount)
