Hi!
I have a Fractal desing node 304 case.
Today I decided to clean the front anti-dust mesh and I noticed that the two front 92mm fans are not spinning. If I spin them by hands or swich the fan speed to a higher level they start to spin and won't stop on lower rpms.
When I connect the back 140mm fan to the same slot it works fine, so I dont think that the problem is the built in fan speed switch.
Any ideas?
Many thanks for the help!
Any ideas?
