Hello,
a gamer wants his better rig, modifying older components. The new additions to the already-working rig (used for non-gaming purposes) were the addition of PNY RTX 3090 and a new fast monitor (165ms refresh). The thing booted up (we saw this on the monitor as well) and suddenly lost all the signs of life. No, there is no limitation in the power supply (750W Corsair, and the system does not have anything power-draining besides this GPU). Since several attempts to switch the system on resulted in nothing, a new power supply was purchased, and when it arrived, we pressed the power button on the unmodified system again, just for the hell of it.... And it turned on! But the monitor shows black screen. Yes, it is connected perfectly fine, via the only card's HDMI port, and as I mentioned, we have seen the boot screen in the beginning. The card - PNY RTX 3090 - is a suspect, since 1 fan out of 3 is not spinning. The card was purchased refurbished. Any hints? To anticipate the question, all the 8-pin card power connectors (there are 2) are connected via separate lines from PSU, no iffy solutions here. The guy has zero budjet at the moment.
