Hi so, I've planned to treat myself and my little OEM pc with a GT 1030, just for that low/medium settings 720p gaming.
The problem here is, I don't know if my power supply can keep it up.
My PC specs are the following:
-Pentium G3250 3.2GHz
-8 GB DDR3 ram @1333MHz
-Intel HD graphics (obviously)
- A CD-RW thingy (I plan on disconnecting this)
-WD Blue 500GB 7200rpm HDD
-OEM motherboard so I really cannot give you an exact spec, but Speccy says it is from a company called Inspur.
By searching up my parts in PCPartPicker, the total TDP is around 152w (without the cd-rw lector), if you add the gt1030 the total TDP will be around 172w, which may look fine. The thing is that my power supply is rated only for 200W (either continuous or maximum, I really don't know) and I'm scared that while I game or do anything at all the whole system just shuts down because it runs out of power. I've thought of undervolting the gt1030 just so it can keep up, but I really don't know + I have little to no money to buy a new PSU. Please tell me what should I do🙁
