A Keyboard problem
Nov 1, 2018
1) Shift + @' key = " 2) Shift + £/3 key = # 3) Shift + " = @
Why have I got this problem, and how do I resolve it??
Suggestions for a solution: still not sure about the source or origin of the problem.
With a four year old keyboard it may simply be at EOL (End of Life) as designed...
You could try new batteries and/or move the USB receiver "closer" with a USB extension cable.
However, you would likely be having far more "keyboard" problems than just the key presses you describe.
Another consideration would be some key press remapping via game software or a utility.
But again, I think you would be having other keyboard issues as well or be aware that the key press combinations had been remapped. (Barring some buggy update or utility.)
New keyboard - perhaps so.
Try another keyboard on your system. Try your keyboard on another system.
Determine if the problem follows the keyboard or stays with the system.
Over time we tend to become accustomed to things and not necessarily notice some decline or growing issue.
Then someone else comes along and can tell that the keyboard has deteriorated or otherwise not as it should be.
Let some one else type and get their opinion.
