A little help hooking up the power please
wevie13
56
Hey guys. I am working on my very first PC build and I need a bit of help figuring a few things out.
MOBO: ASUS P8Z77-V
PSU: Rosewill Capstone
GPU: AMD Radeon 7850
I am a bit unsure how to hook the power to the GPU and a unsure what to do with the CPU1 cable. I am pretty sure that the 20+ 4P goes to the right of the RAM. Where else could it go right?
What stumps me is the CPU1 and how to hook up the GPU. Just it connect to the MOBO? The only place I see that it could go is the top left of the MOBO.
With the GPU, do I use the PCI Express and SLI Ready or do I use both cables and only use the PCI Express on each one? Also, I am assuming that I just use the 6-Pin part of the connector and leave the additional 2 hanging free?
Here are the pics. Thanks for any help!
Where I think the 20+ 4P goes
Is this where CPU1 goes?
I have two of these. Is this what I use to hook up the GPU?
20+ 4P
CPU1 connector
GPU
ther 20+4 goes in the long slot next to the ram. it will only fit 1 way. if theres 4 slots left over then plug the +4 in as well.
use the 2x4 atx leads in the 8pin atx on the left of the cpu, not the high voltage 6+2pins they are for the gpu. again they will only fit 1 way.
cLick1338
13
The 24-pin goes to the right of the RAM, the SLI-ready and PCI-Express ones both go in the GPU (order shouldn't matter), and for the CPU... there should be a 2 by 4 one (it's like LEGO!).
wevie13
56
So just one cable for the GPU. Use the SLI-ready for one 6-pin and use PCI-Express in the other 6-pin on the GPU
The CPU1 connector is what you are calling the ATX 8-Pin right?
So this
in this
and this
in this
Thanks to both for the quick response
btw congrats on your first build. make sure your reading the manual page by page and following each step. do it this way may take you half an hour longer but it will save you 4 hours trying to figure out where you went wrong...
things you need to pay particular attention to.
the memory and which slots it goes into.
the front pannel connectors from the case to the motherboard.
make sure you get the power and reset buttons in the correct order as well as the hdd and power lights. seriously make sure you look in the manual for the wiring diagram. also make sure you have the case enclosure instructions to hand when wiring the front panel. often they can have slight revisions which you may need to take into account.
but like i said your off to a good start. just take your time and keep reading as you go...
Latest posts
