A Little Help!
Aug 17, 2018
Hey Hey!
So.......
I am building my first ever PC from scratch. I have dabbled in the past but never a full build or anything approaching high-end. I am far from an expert but learning what to do has been fun....trying to balance bang for my buck with matching components & some future-proofing.
The system will be used for both gaming and work so I have opted for AMD......well really I am going AMD because my monitor is 1440p with FreeSync and I am getting a PowerColor Radeon RX VEGA 64 Graphics Card for a great price from a miner friend.
After reading as much as I could and watching videos etc. I have come close to what I think will be my build and it is within my budget. I was hoping that some of you that are more of an expert than I could take a look and advise:
1. What RAM would you recommend? I want 32gb. 2 x 16gb preferably so I can extend to 64gb later. Everything I have read has said that the fail-safe for buying memory is to check the OVL of the Mobo or the RAM Manufacturer. For x470 boards I am finding it hard to find 3000+ Memory that is recommended.
2. If there is anything you would switch up/out from the build and why? I don't need the X470 Taichi Ultimate as 10gb p/s is not a concern! 😀
I won't be overclocking (at least initially) so I want to get this as right as I can out of the box. So I don't think I need to watercool and from what I can read/see the Noctua NH-D15 SE-AM4 should be enough if I get the airflow in my case correct - and its thermal paste is meant to be good.
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor
CPU Cooler: Noctua - NH-D15 SE-AM4 82.5 CFM CPU Cooler
Motherboard: ASRock - X470 Taichi ATX AM4 Motherboard
Memory:
Storage: Kingston - A1000 480GB M.2-2280 Solid State Drive
Storage: Team - L5 LITE 480GB 2.5" Solid State Drive
Video Card: PowerColor - Radeon RX VEGA 64 8GB Video Card
Case: Cougar - Panzer Max ATX Full Tower Case
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Cheers,
The Banana
Yeah, that cooler surprised everybody considering how bad coolers AMD had for older processors. It's made by Cooler Master specially for 2700x, no other processor has it.
My RAM right now is two of Kingston HyperX KHX3600C17D4/8GX and is working fine at 3600MHz Cl16 although on x370 MB wouldn't go over 3333MHz.
There's diminishing real world usage gains with RAM higher than 3200MHz so you might want to keep that in mind.
