News A new PCB design can boost heat dissipation by 55x – copper coins placed under heat generating components drop temps drastically
I think this stepped design is going to work well in exo-atmospheric conditions. Our endo-atmospheric electronics have the benefit of utilizing 2 separate heat transfer methods to release heat into the environment (radiation and convection) whereas exo-atmospheric only has one (radiation). So it makes sense that the stepped coin has a larger diameter at the other end of the chip being cooled in order to improve the heat dissipation if relying solely on the stepped coin for cooling, or efficiently using the stepped coin to act like a thermal vacuum to transfer heat to the next piece of the radiative cooling method (IE the larger side of the stepped coin can move more heat energy if each side is the same temperature (but lower than the heat source temperature), this creates a thermal gradient between the sides of the coin that then makes thermal transfer more effective through the coin using the thermal conductivity formula: watts per meter-kelvin where kelvin is the delta temperature between the sides of the coin).
https://upload.wikimedia.org/wikipedia/commons/9/9a/Simple_definition_of_thermal_conductivity-en.svg
Radiative heat dissipation requires a lot of surface area to transition thermal energy into infrared radiation that can be released into a vacuum efficiently in order to achieve a similar dissipation rate to endo-atmospheric equivalents.
I think I've seen similar solutions before. I don't know enough about the technology to understand what is novel about this one in particular.
It is also commonplace on very conventional processes to have component footprints with large copper pads on both sides of a PCB and a dense grid of vias in-between them.
Reactions: kjfatl and frankens
I think this stepped design is going to work well in exo-atmospheric conditions. Our endo-atmospheric electronics have the benefit of utilizing 2 separate heat transfer methods to release heat into the environment (radiation and convection) whereas exo-atmospheric only has one (radiation). So it makes sense that the stepped coin has a larger diameter at the other end of the chip being cooled in order to improve the heat dissipation if relying solely on the stepped coin for cooling, or efficiently using the stepped coin to act like a thermal vacuum to transfer heat to the next piece of the radiative cooling method (IE the larger side of the stepped coin can move more heat energy if each side is the same temperature (but lower than the heat source temperature, this creates a thermal gradient between the sides of the coin that then makes thermal transfer more effective through the coin using the thermal conductivity formula: watts per meter-kelvin where kelvin is the delta temperature between the sides of the coin).
I for one welcome our new discouragement of extraatmospheric copper theft using anodized or graphene fill slug PCBs. (Or is it Millions for launch and nothing for treaty, I forgot.)
Placing copper under hot components has been a pretty standard practice for 50 years. Some components are even soldered to this large copper 'coin'. Standard for most non heat sinked power transistors/ drive circuits. Also introduces a ground plane to reduce noise. Pretty common in the radio industry
Reactions: kjfatl
Not integrated into a PCB, so not really relevant in my opinion
I'm having difficulty understanding what is 'new' here that we have not been doing for decades. An close array of vias, plated solid with copper under the 'exposed pad' of part above. What are they doing different? Cutting a hole in the PCB and filling it with a copper slug? If so, they might double the thermal capacity over standard design practice. For this to be optimal, the slug would have to be inserted before plating the through-hole vias in order to insure good thermal connections to inner layer planes. I wish this had been better explained in the article. Nothing stands out on the supplier's website either.
Reactions: bit_user
What is new here? This is just a heatsink in a different form factor. Normally heat sinks are placed on top of a component, these are just placed under them. Like has already been mentioned thermal pads already exist for this purpose, yes these might be better but for most uses they probably aren't that much better.
Radiative cooling depends on surface area and your limiting factor in cooling will likely be how much you can radiate, not conducting the heat to the radiative surface, so an exposed copper pour on the PCB connected to the thermal pad under the component with vias would likely be as good in a lot of circumstances.
Reminds me of seeing a PCB used for military aircraft. It had a large sheet of metal over the board to create a Faraday cage around the card to prevent EMP damage. Trying to probe the board to see if it worked properly was a nightmare.
Reactions: bit_user
Copper is a thermal conductor.... Noooooo 😮!
Motherboards have been doing this for a long time now. Making it a sheet or a coin is simply a variation of the same thing, but hardly something new.
