[SOLVED] A power supply with dimensions like 250x120x49mm or smaller?
PythonSchlange
5
Hello,
I search a power supply, which has dimensions like 250x120x49mm or even smaller.
Thanks
Just so you're aware, there are other lower quality Flex ATX PSUs on the market for around $30, but most of the ones I found aren't even 80+ bronze certified, which speaks to their quality (or lack thereof). One thing to consider with these small units is that > efficiency = < waste heat and when there's a tiny 40mm fan in charge of cooling, less waste heat is easier on the ears.
