[SOLVED] A question about a good 45w charger for the note 10 plus?
If the charger is power delivery 3.0 certified, it should work without any problem, no matter what brand it is.
Aukey seems OK.
However it's pin may not be compatible with your socket and you might need a universal plug or extension board to make it work.
I'm not 100% sure but i'm guessing that that default cable will work.
and if you want, you can check the charging speeds using an app called Accubattery.
It will let you know whether you need to upgrade your cable or not.
There are many more apps that can tell you about the current and voltage, like CPU-X, CPU-Z, Ammeter, etc but Accubattery is an app that's dedicated for the battery.
It undoubtedly works the best.
