Howdy Everyone,
I recently installed 4 brand new Arctic P12 fans into my System, 3 intake on the bottom, 1 exhaust on the back.
In the process I have daisy chained all D-LED connectors together, starting with the first fan from the left ending with the exhaust fan on the rear:
After this I have hooked them all up to 1 single D-LED Header.
The problem I have, is that this exact fan, as in the one marked with the arrow which begins the daisy chain, is not synced with the other two (middle, and right, The exhaust doesn't bother me) when the "Digital Wave" or rainbow effect is being displayed.
All colors "spin" at exactly the same rate/speed and the left fans effect spins in the same direction but in reverse order.
So if fan middle and right are passing colors, left fan shows at the same spot the exact opposite of the color wheel and vice versa.
My mobo is a B550 Pro V2, each header can handle up to 1k LED's. The fans have 12 each. So def not that.
Wrong way connected can't be, right? Since it's 3 pin and 1 pin is "blocked" so it's foolproof.
The fans are also physically definitely all installed identically as intakes, and the logo on them points into the same direction.
Any ideas?? The effect is consistent through reboots
Note: This is my first time messing with RGB, maybe they aren't supposed to sync in that way, I do not know. Just looking for help. Thanks!
