[SOLVED] A VR System advice needed
Solosheep_UK
4
Hello
Long time no post from me!!
Its my birthday next week and I know I'm being got a Oculus Quest by my wife. However she does not know much about PC and Gaming and did not realise that my Very Old PC with an 775 motherboard wont be able to play Half-life Alyx etc. So it looks like I'm buying myself a new system.
Now I must admit I have been out of the loop a few years on systems I'm not looking at the high high end of Gaming PCs as I don't have much time anymore to game but would like to play half life etc bring back my childhood. so I have been looking at this system with an upgrade to the AMD Ryzen 9 3900 - 12-Core 3.10GHz, 4.30GHz Turbo
https://www.cyberpowersystem.co.uk/system/Half-Life-Alyx-Ryzen
Would really like to understand the pros and cons based on what I need also not looking at spending much more than £820 etc
Thanks guys
I have done some tweaking what do you think of this? And come up with a 5500xt and total rig price £830
Case: Cyberpower ONYXIA Mid-Tower Black Gaming Case w/ USB 3.0, Front & Side Tempered GlassCase Upgrades (Fans and Lighting): None SelectedCyberpower Noise Reduction Technology: None SelectedCPU (Processor): AMD Ryzen 5 3600 - 6-Core 3.60GHz, 4.2GHz Turbo - 32MB L3 Cache Processor, Pro OC Compatible (No On-board Graphics)CPU Freebies: None SelectedCPU Overclocking: No OverclockingCPU Cooling: Cooler Master Masterliquid Lite 120 Liquid Cooling System w/ 120mm Radiator, Extreme OC Compatible (Cooler Master CPU Water Cooling, Extreme OC Compatible)Coolant for Cyberpower Hyper Liquid II Cooling Kit:None SelectedSecond Coolant for Cyberpower Hyper Liquid II Cooling Kit (Dual Loop Only): None SelectedMotherboard: ASUS PRIME B450-PLUS: ATX w/ RGB, USB 3.1, SATA3, 1x M.2Memory (RAM): 16GB (2x8GB) DDR4/2400mhz Dual Channel Memory (Corsair Vengeance LPX w/Heat Spreader)Graphics Card (GPU): AMD Radeon RX 5500 XT 8GB - DX12® - VR Ready, HDMI, DVI, VGA, 3 Monitor Support (Single Card)Graphics Card Freebies: None SelectedVideo Capture: None SelectedPSU (Power Supply): InWin A55 550W 80+ Certified Gaming Power SupplyPSU Braided Cable: None SelectedSolid State Drive (SSD): 250GB Seagate Barracuda 120 2.5" SSD - 560MB/s Read / 540MB/s Write (1 Drive)
