bolo511 Jun 11, 2020 2 0 10 Jun 11, 2020 #1 My A6 5400K stock cooler is currently at 40-50 Cº, and i want to upgrade to an Athlon x4 760k, should i buy a new cooler?
Solution popatim Jun 11, 2020 The A6 is a 65w part and the Athlon is a 100w part. - You need a new cooler as well.
popatim Titan Moderator Dec 2, 2009 38,904 980 135,890 Jun 11, 2020 Solution #2 The A6 is a 65w part and the Athlon is a 100w part. - You need a new cooler as well. Upvote 0 Downvote Solution
Gerald6049 Estimable Jun 9, 2020 786 85 3,040 Jun 12, 2020 #3 on the paper, yeah you should get a new cooler, but in the reality you don't know it will be fine or not. just try it and see. if its overheat, buy a new cooler. Upvote 0 Downvote
