Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
On Wed, 5 May 2004 20:43:57 -0400, "Paul E. LePage"
<Paul1@chartermi.net> wrote:
>Hi, I finally got mine to run 200mhz FSB. Tried the same Kingston;
>KVR400X64C3AK2/1G that you have. Kingston engineers said it should work ok--
>Runs at 200, but is visibly slower than the old Kingston I had, even running
>in dual channel. Decided to try Cosair (on ASUS QVL) CMX512-3200C from
>MWAVE, their part number BA08584, so far its running GREAT at 200mhz, dual
>channel, set 8,3,3,2.5. Athlon XP3200 A OK at 2200mhz. Will run memtest86
>and benchmark next week-I'll post results. Good Luck! Paul
>"Ron Todd" <rltodd@ix.netcom.nospam.com> wrote in message
>news:t5jg901uhat7r8lmj5r9e9idpvqjbg9q9p@4ax.com...
>> On Sat, 01 May 2004 22:34:32 GMT, Andrew J <ajpk3@hotmail.comremove>
>> wrote:
>> >>I'm wondering what to do next if I get both of them to run 197mhz, or
>> >>so single, but no more than 180mhz dual channel????
>> >Run them both single channel(first 2 slotts) if you can. Dual channel
>> >is great on paper but in real life not so much. Having your Sandra RAM
>> >scores go up 4% means very little to most users.
>> I installed a Thermaltake Silent Boost cooler an I now have it running
>> well at 185. I had it at 190 for about three hours, then started a
>> google search and it did a reboot on me. I'm think I will try upping
>> the core and ram voltages next.
>> Are those clip on, aftermarket ram heat sinks like Thermaltake worth
>> it? My mother board is currently 22c/71f according to ASUS Probe.
>> tnx
Bit the bullet and bought the Corsair 3200LL set. It has been running
rather nicely for the last six hours at 197/197. I had it at 200 for
about an hour and then got a hang. I got a strange message back from
MS crash analysis about the ATI driver being a problem and upgraded
that from the ati site. Tomorrow I might step it back up to 200 and
see if it will hold. I conclude that this board did not like the
Kingston memory and I have an "issue" with Mwave.com.
Tnx for the help.
