A7N8X-VM & 4ch audio
fin
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I can't seem to get the rear speakers to work, front speakers work like a
champ. I installed the NVidia 3.13 drivers and the RealTek audio driver
from the Asus web site. I checked the tick box in Windows sound properties
that says 'Rear connected to Mic'. I am using Windows XP latest.
I can't find anything in the manual that says 6ch audio is supported at the
analog ports provided, do you have to use SPDIF??
Thanks!!
>Thanks!!
You should be able to configure it for 4 (analog) speakers using the Realtek control panel. You may also need to set
Windows Advanced speaker settings to quad or something (I forget, been using a audigy2 for awhile now).
Latest ALC650 drivers...
http://www.realtek.com.tw/downloads/dlac97-2.aspx?lineid=5&famid=12&series=8&Software=True
Ed
