A7V400-MX boot and onboard audio problems
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I'm taking a survey to see how commone the following problems are:
Boot problem 1: Everytime I turn power on from a cold start, boot starts
for about 2 seconds, then HDD and power lamps go off for about 2
seconds, then come on and boot continues normally. Definitely not a
power supply problem. Does your m/b ever do this?
Boot problem 2: Sometimes, I get a message that the keyboard is locked
out and there is no response to any key presses. If I then hit Reset,
next boot proceeds normally. Ever happen to you?
Audio problem: Can't get onboard audio to work. I thought I installed
all the drivers properly and have AC97 enabled in the BIOS. Have any of
you ever got onboard audio to work?
All I'm looking for are simple Yes/No answers to each question. If most
of you do NOT have these problems, I'll assume that my m/b is defective
and exchange it.
Thanks for your help.
Ray
No
No
My onboard audion work as expected
I used to have a t-bird 1GHz on it and now I have a xp-m 2500+. Both work.
On Wed, 12 Jan 2005 10:34:57 -0800, No e-mail
>No
FWIW - I have this happen on my A7V8X-MX mobo
>No
>>No
I just built up a box with a A7V400-MX today, and it does it too.
