A7V8X-MX and Barton 2500+ problem?
ChrisR
61
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have one of these oldish boards as a standin for my nforce2 board
which died. I take it my Mobile Barton Core 2500+ doesn't work so well
with this board? It detects it all right, but runs it at 1000 Mhz and
there are no options to change the multiplier that I can see and the bus
only goes to 166Mhz? Am I missing anything? Thanks.
ChrisR
61
Though interestingly enough, because its a mobile I can switch the CPU
speed and voltage up under windows....didn't know what until now. So
currently I'm at 2.3 Ghz.....fast enough for now.
G
Guest
Guest
mobile bartons start up at default 6x multiplier, with the default 133
fsb that equates to 800mhz, but with 166fsb that is 1000mhz. maximum
intended speed for a mobile 2500 is 15.5x133, about 2ghz.
dr ratt
gary: so there's no chance we can be together?
lisa: only if you promise me you'll never die.
gary: you know i can't promise that.
lisa: if you could do that, i'd make love to you, right now.
gary: i promise. i will never die.
Similar threads
