AB350 gaming 3 gigabyte DRAM AND Split second cpu light
Hey! guys I dont post on here at alot i mostly come here for fixes for my problems and Ive seen a bit of my problems fixed but on others rigs
MY PC
CASE: nzxt source 250
MOBO: Gigabyte AB350 - Gaming 3
CPU: 1300X Ryzen AMD quadcore
RAM: Pacific Sun Memory 8gb (2133mhz) Single Stick
GPU: GTX 750 TI
PSU:ThermalTake smart 600w 80plus
The Issue is that there is no post everything turns on the cpu fan and the gpu fan and all that, the motherboard just gives me the DRAM LED light with a split second cpu light on
Ive tried a couple of methods of fixing this issue like cmos reset
and swapping my single stick of ram in different slots as well as making sure my cpu was in flush in the socket, Also followed the manual for install the proper wiring for the f_panel ive also waited for a post 15+ minutes but nothing i would really appreciated if someone can help!
1. Is the computer unplugged when you clear the CMOS?
2. Try booting with the graphics card in the 2nd x16 slot.
I bought some new ram Corsair Vengeance LPX 2400mhz 8x8 16gb i heard the ram doesnt need to be on the list to be fully compatible and im still getting the same error i installed both sticks into slot 3 and slot 4 and i removed one stick and still the same issue im starting to give up ive been to the store so many times i cant count :C
i had the same problem yesterday fixed it today, here is what you have to do after you power it on press try press the restart button for 15 to 20 seconds. if it posts you will have cleared the Cmos and you will also be able to tell if all the components are okay because it will continue on to windows and etc
