Acer Aspire M1100 video will not start my monitor
silverback57
I have an acer tower M100 PC and the monitor would not come up. I changed the monitor and same problem. The pc appears to have no plug in video card so I bought a new motherboard and installed it. Upon turning it on the power supply ran about 5 seconds and kicked off. If I unplug the AM? connector the unit will remain running but still no video. I installed a new 450W power supply and same problem. I connecter the monitor using existing cables and the monitor wored fine from my laptop. I reinstalled the old mother board with new power supply and the unit will start and run again with all wires connected but still no life to the monitor. I have tons of personal data I want to retrieve, did not think to back it all up, and am at my end as to what next. There are open slots on the board and did not find any video card in any ports when opened up so I am guessing the original vidoe is integrated into the motherboard itself? What am I missing other than enough experience to fix this problem. Its an old PC and all I want is my data. The vista software was preloaded. Where am I at on this one?
I did have an episode prior to all of this where I would have start my PC over and over dozens of times to get the monitor to come on but when I installed the new monitor it was better but still not 100%.
Thank you sooooo much for posting this. I have been without my computer for about 5 days and even ordered a new power supply, which of course was not the problem. I replaced the Cr2032 battery (a free fix for me because I had a bunch of them on hand) and bam all good. I wish I had read this post 5-days ago. Thank you again!!!!!!!!
Super when I changed the battery, it worked!!!!!!!!!!!!! Thanks man you are a king!
to Happy Camper2013 , you're the man! I was about to leave the house to get a replacement motherboard (as if there's any!) when I decided to do some research. Replaced the cmos battery, and it all went good. thanks!
New CR2032 battery fixed it for me as well.
However...SHAME on Acer (or really the motherboard manufacture) for such a crappy design. The battery should not prohibit the PC from posting/booting. All the battery is (supposed to be) there for is to retain the CMOS information when A/C power is not supplied. That way you don't have to reconfigure the CMOS every time you power it off. Having a dead battery should only mean that each time you turn it on, you're forced to re-enter any configuration information...which is usually only the date/time as most of the important stuff is detected automatically.
Just another reason I would never buy a name brand computer such as this (I'm fixing this computer for someone).
Thanks for the easy/quick fix though Happy Camper2013. I was really worried about having to find an exact match motherboard since i really cant reinstall the OS to work with a new board.
