Acer "x3810" Low Profile Graphics Card "HELP"
denkikoiji
oke well here is everything that my System information says:
OS Name Microsoft® Windows Vista™ Home Premium
Version 6.0.6001 Service Pack 1 Build 6001
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer Acer
System Model Aspire X3810
System Type x64-based PC
Processor Pentium(R) Dual-Core CPU E5200 @ 2.50GHz, 2500 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date AMI P01-A3, 5/26/2009
SMBIOS Version 2.6
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "6.0.6001.18000"
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 3.96 GB
Available Physical Memory 2.45 GB
Total Virtual Memory 8.14 GB
Available Virtual Memory 6.32 GB
Page File Space 4.26 GB
Page File C:\pagefile.sys
Name Intel(R) G45/G43 Express Chipset
PNP Device ID PCI\VEN_8086&DEV_2E22&SUBSYS_02501025&REV_03\3&11583659&0&10
Adapter Type Intel(R) 4 Series Express Chipset Family, Intel Corporation compatible
Adapter Description Intel(R) G45/G43 Express Chipset
Adapter RAM 1.76 GB (1,894,344,704 bytes)
Installed Drivers igdumd64.dll,igd10umd64.dll
Driver Version 7.15.10.1666
INF File oem17.inf (iEGL0 section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1600 x 900 x 59 hertz
Bits/Pixel 32
Memory Address 0xFE400000-0xFE7FFFFF
Memory Address 0xD0000000-0xDFFFFFFF
I/O Port 0x0000DC00-0x0000DC07
IRQ Channel IRQ 16
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\igdkmd64.sys (7.15.10.1666, 9.80 MB (10,276,352 bytes), 4/8/2009 11:17 PM)
PNP Device ID PCI\VEN_8086&DEV_2E23&SUBSYS_02501025&REV_03\3&11583659&0&11
Adapter Type Not Available, Intel Corporation compatible
Adapter RAM Not Available
INF File oem17.inf (iEGL1 section)
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xFE300000-0xFE3FFFFF
*Update*
Power supply: 220 watts T^T its small
Ok That is all my info and i would to add a new hd graphics card to my desktop i have 1 open space and i have no idea what one to get all i want is the best one available for me the max i want to spend would be oh $250.00 or so so anything under that plus i want to upgrade my 2 open ddr3 ram slots with two 2gb ddr3 sticks so i hope i can get some help ^^ thank you ^^.
i just got the new gfx card in the mail and guess what !!! my case is to small T^T now that means i cant use it till i get a bigger case or cut space into my current case lol...gahh so annoying + how do i plug it in for the power to the fan i think im gonna have to run a separate power block cause the one i have in the pc has to extra connections T^T and there plugged in to my motherboard lol...
The only Graphics card that you can safely use with Acer Aspire X3810 is the Geforce 220 GT. (This info comes directly from the manual for that PC).
