Question Acer XF250Q 240hz Monitor Settings
Rickle
22
Hello, I am looking for the best settings for my Acer 240hz monitor. I would like to have the most amount of refresh rate and vision possible. I compete at the highest levels of gaming and I want every little advantage I could possibly have, and should G-sync be on or off?
G sync is OK to enable, it will just match your frames to the monitor refresh rates to make it smoother. Not sure what you mean by "most vision", if you mean what you can see on the screen, that depends on the game quality setting.
I mean the least amount of blur/ghosting when doing fast shots
