Acquired XP Pro problems-To much junk running at startup
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
After log-in I look in task manager & see all kinds of apps running. Where
do I go to stop this stuff from loading at start-up?
Also, how do I log on as administrator?
I try to get HELP but Explorer never loads the docs.
AHHH, Help.
I can not run sfc/scannow at run, could anyone give me help. Thanks
> AHHH, Help.
> Where do I go to stop this stuff from loading at start-up?
On the Start/Run line type: msconfig When that opens click the Startup
tab to see what all is being loaded each time you boot.
Boot into Safe Mode as one method. If you only see one name on the Welcome
screen that most likely you are the system administrator.
....Sky
Hi;
Why do you think you need to run that? That are probably better options
available for most issues.
....Sky
Thanks Sky, being a new user,what might be the better options, you don't
say....
"Sky King" wrote:
> Hi;
> ....Sky
> say....
I can't say what other options you may have until I know why you want to run
SFC. What is the problem you are trying to correct?
....Sky
Check out www.blackviper.com for what and how to manage XP
start-up.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"Sky King" <skyking@mvps.org> wrote in message
news:eyty9RK0EHA.2012@TK2MSFTNGP15.phx.gbl...
options, you don't
| > say....
why you want to run
| ...Sky
