Adding memory,help
D
Yep that would work fine. That memory will also fit under the big air coolers if you are overclocking.
I see you already have 8GB, can't you just find another kit to match the 8GB you have now? You sure you need 16GB? For gaming 8 is plenty.
That GSkill linked to above is excellent. It will work fine with your system and is about the best "bang for your buck" right now.
