Adjust for Wide Angle lens distortion
Billh
60
Archived from groups: rec.photo.digital.slr-systems (More info?)
Is there a way in Photoshop to adjust for the distortion when
using a wide angle lens (e.g. 17mm)?
Thanks...
> Thanks...
There's some software designed for panoramas and other image stitching,
called PanoTools. It's free, and it's being packaged by about a zillion
different people. One of the things it's designed to do is adjust for
lens distortion. There are PS plugin versions of it. Start here:
<http://panotools.sourceforge.net/>.
>Thanks...
Use freetransform and skew, and crop.
ken
"billh" <billh@nospam.att.net> wrote in message
news:420C6DAC.7BE5D2C7@nospam.att.net...
Yes, download the free PTlens plugin for Photoshop at:
http://www.epaperpress.com/ptlens/index.html
Also download the "PTlens helpers" and "Profiles" from their download
page.
Bart
> page.
Thanks Paul & Bart... Looks promising!
Bill
Ken Ellis <kenellis@nycap.rr.com> wrote in
news:0hip011g74r2e0lht8a83j8dva7mmngv0g@4ax.com:
>>Thanks...
Hmmmm ... how?
/Roland
"Roland Karlsson" <roland_dot_karlsson@bonetmail.com> wrote in message
news:Xns95FAED4ED1580klotjohan@130.133.1.4...
>>>Thanks...
> Hmmmm ... how?
It's all there in "Help"
I tried it after seeing this post and it's just great for getting rid of
converging verticals.
On 11 Feb 2005 22:19:42 GMT, Roland Karlsson
>>>Thanks...
>Hmmmm ... how?
>/Roland
If you can't get it with the help, let me know and i'll try to explain
it. It's fairly easy.
rgds
Ken
>>>> Thanks...
>> Hmmmm ... how?
>> /Roland
> rgds
> Ken
Isn't barrel correction one of the primary requirements? Is that in
Photoshop?
(Yes, it is in Paint Shop Pro, as is a rather handy perspective correction
tool).
Cheers,
David
"David J Taylor" <david-taylor@invalid.com> wrote in news:376231F5865icU1
@individual.net:
> Photoshop?
No it is not IMHO. You can correct perspective in Photoshop,
but not distorsion (without a plugin).
Some here wants to tell me how it is simply done in Photoshop.
If they can, then I stand corrected :)
/Roland
On 12 Feb 2005 10:45:19 GMT, Roland Karlsson
>@individual.net:
>> Photoshop?
>/Roland
I beleive you can acheive some similar results with the "sphere"
filter in photoshop - filter>distort>sphere (or spherize) where 0 is
no effect and +/- would debarrel and barrel ...lol
rgds
Ken
news:vbur01p0g1cpdt5u5kmo6l7hdktfje0rq7@4ax.com:
Yes - you may be able to use that filter. It is not easy and
it is not certain that you can. You only have a slider for
amount - and lens distortion is somewhat more complex than that.
OK - I missed that filter.
But - that was not really my point. At least two posters claimed
that you could fix distortion easily with skew and distort. I
asked them to show me how.
/Roland
Alan Browne <alan.browne@freelunchVideotron.ca> wrote in news:culgc5$7fc$1
@inews.gazeta.pl:
>> Hmmmm ... how?
> You've been led to the well. Pump your own water.
According to my knowledge you cannot use free transorm, skew and crop
to correct distortion. You have to have some kind of non linear
transform to do that.
So - I think that I have been led to a useless well.
Please show me that I am wrong?
/Roland
On 12 Feb 2005 22:10:43 GMT, Roland Karlsson
>@inews.gazeta.pl:
>>> Hmmmm ... how?
>/Roland
Well...With the free transform..etc you can approach converging lines,
etc; also you can rotate the pic like a 3d object and correct it that
way too...and the sphere filter will definately do what a debarrelizer
does (per se)...so betwean all that i suspect that you have to tinker
with them to get what you want....because what's to say what is
distorted..and what isn't. You'll make that decision when you pinch
and pull and tug on the thing; and change it...what "distortion" are
you trying to fix?
rgds
Ken
> you trying to fix?
It sounds a lot more complex than the equivalent Paint Shop Pro 9 steps:
- step 1, apply barrel correction, needs one number
- step 2, apply perspective correction. Draw four lines on your picture
showing what elements comprise a rectangle, and tick Apply.
Perhaps it's easier than it sounds once you have experience of the tools
in Photoshop.
Cheers,
David
> @inews.gazeta.pl:
>>>Hmmmm ... how?
Not as far as I know. I've used Image|Transform|Perspective to correct
architecture shots from a 20mm lens. (Okay, that's not 'freetransform' but it's
in the same transform menu).
To be clear, it can correct for the perspective error; it cannot correct for
known 'flatfield' error of the lens.
http://www.aliasimages.com/images/ManoirLorraineLR00090010NC.jpg
http://www.aliasimages.com/images/ManoirLorraineLR00090010PC.jpg
Best to 'squeeze' the wide part to narrow than to stretch the narrow to wide.
Cheers,
Alan
-- r.p.e.35mm user resource: http://www.aliasimages.com/rpe35mmur.htm
-- r.p.d.slr-systems: http://www.aliasimages.com/rpdslrsysur.htm
-- [SI] gallery & rulz: http://www.pbase.com/shootin
-- e-meil: there's no such thing as a FreeLunch.
news:ekit01p1h0pk2b4fr74j8u0qvu0nchdd7v@4ax.com:
> you trying to fix?
I know how to fix distortion. I do it with panorama tools.
And I now know that there is a sphere tool in Photoshop,
although it looks more like a toy than a real tool.
I is just that some here said to me that I could use crop, skew
and free transform to do it. And when I asked how, they said
that it is now up to me as I have been led to the water hole.
I think it is sux big time to pretend being expert and pointing
at some tools - when you are wrong. And I also think it sux
big time to not admit that you are wrong.
Note Ken - that nothing what I write here fits you. Your replies
have been helpful. Others was just nonsens.
/Roland
>>you trying to fix?
Tsk, tsk. See my other reply. And example. Imperfect though it is (not
knowing the lens distortion) it works.
Cheers,
Alan
"David J Taylor" <david-taylor@invalid.com> wrote in news:378tn7F59eu60U1
@individual.net:
> in Photoshop.
You are perfectly right. Photoshop has no built in distortion correcter.
It neither has any easy to use perspective correction. The method you
describe for perpective correction is several times more convenient.
If you have Photoshop, and want to work with it efficiently, you have to
get some plug ins.
/Roland
> @individual.net:
>>in Photoshop.
Image -> Transform -> Perspective. (Not a plugin). Easy to use.
"Alan Browne" <alan.browne@freelunchVideotron.ca> wrote in message
news:cuofjl$3ma$2@inews.gazeta.pl...
There is no such function on my copy of Photoshop 8 CS.
So anyway.... There's alot of tools in potoshop. I'm no expert..but i
suspect you might be able to create an action that would give
you a vanilla correction.
Fundamentally, it's a loaded question, because imo you are paying for
that "distortion" by going wide angle - it's what it does. The best
correction might be using a longer lens - or factor, and making a pan.
I have wished for a composite of both effects...which i suppose will
entail me learning how to fix parts of the pic - like the right and
left sides of a wide angle shot where everything is streched; but
maintain the distortion in center field.
But..if i was to stick to the point - the original question - then the
mentioned "familly" of controls is the answer. You can get in there
and tweek the heck out of them..and that seeming complexity
- that contol - is what ya pay for. It's why alot of folks use the
thing to begin with.
As far as the notion of "plugs" go, they are "controls" and if
you want to build your own...i believe you can. Plugs are just
that...someone farmed the runtime or api for functionality, or added
to it via it's interface/component extensiblity..that's cool.
I don't know paint shop at all...wish i had a copy cause i've seen
some neat stuff done in it; but how much do you want to learn.
It becomes daunting...
I enjoyed the question because it made me think about what native
filter did what a debarrelize plug i have did...and now i can fool
with that.
I
f you want to draw a rectangle and hit the button (taylors post) and
you like the result. ...it's all good. Often, i think that would be
appealing. If you want more control...welcome to the complexity.
That's alot of verbage for me and it was easier to just list the
controls; and let someone else say RTHF.
Best to ya's all
Ken
"Rudy Benner" <bennerREMOVE@personainternet.com> wrote in message
news:110vl418ts7mo0b@corp.supernews.com...
>> use.
Alan just made a small typo.
First "Select-> All, and then EDIT -> Transform -> Perspective.
Bart
"Bart van der Wolf" <bvdwolf@no.spam> wrote in message
news:420fea76$0$28985$e4fe514c@news.xs4all.nl...
> Bart
Got it. Thanks.
