[SOLVED] Adjustable VESA mount for monitor(s)
ThundyUK
67
Recommend me an adjustable VESA mount for XB323UGP or PG329Q?
Hi folks,
Hope everyone is keeping safe during these odd times.
As the title says I'm looking to get either Predator XB323UGP or ROG Swift PG329Q but the vertical adjustment on both seems a little lack lustre - as in it doesn't go high enough.. It's really important to me that I can get it both flat on the deck so to speak and also high in the air so you're talking about some substantial adjustment like my current BenQ XL2720Z has.
So I'm going to VESA mount the one I get, but I'm not sure what mount to get. I want something that mounts to a desk rather than a wall, and has on-the-fly vertical adjustment - the same as the stand has but with the ability to raise it higher. I can find ones that seem to fit the bill but they're not adjustable without a hex / allen key and I really want to be able to just move it up / down as I need to.
Anyone have any thoughts on a good one please?
Thanks for any help as always
Kind regards
Thundy
