Advance Warfare Freezing and Crashingg
cdg4000
20
So I'm having issues with this game, Call of Duty Advance warfare.. it freezes.. it crashes. It's terrible.. even at the lowest settings...
All my other games work just fine..
Seems like I just ripped off buying this game and it's not even playable...
All other games work just fine though. Like dying light and etc...
My spec:
R9 290 4gb Core edition, I underclocked it for power consumption reasons.
8320 OC to 4.0 Mhz. With Cool master Evo 212
8gb Ram Hyper X.
600 PSU
Tell what I should do cause I don't wanna go to a gtx 960.. they my r9 290 actually is better but it makes no sense that I have issues with a powerful card..
http://tinypic.com/r/2rrp9up/8
Processor 1 ID = 0
Number of cores 8 (max 8)
Number of threads 8 (max 8)
Name AMD FX-8320
Codename Vishera
Specification AMD FX(tm)-8320 Eight-Core Processor
Package Socket AM3+ (942)
CPUID F.2.0
Extended CPUID 15.2
Core Stepping OR-C0
Technology 32 nm
TDP Limit 125.0 Watts
Core Speed 4017.7 MHz
Multiplier x Bus Speed 20.0 x 200.9 MHz
Rated Bus speed 2209.7 MHz
Stock frequency 3700 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
L1 Data cache 8 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 8 MBytes, 64-way set associative, 64-byte line size
FID/VID Control yes
Mainboard Model GA-78LMT-USB3 (0x0000035B - 0x9521BE73)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x1
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 1.22 Volts [0x66] (CPU VCORE)
Voltage 1 1.50 Volts [0x7D] (DRAM)
Voltage 2 4.83 Volts [0xA1] (+5V)
Voltage 3 9.79 Volts [0x88] (+12V)
Voltage 7 3.34 Volts [0x8B] (+3.3V)
Voltage 8 1.61 Volts [0x86] (VBAT)
Temperature 0 44°C (111°F) [0x2C] (TMPIN0)
Temperature 1 47°C (116°F) [0x2F] (TMPIN1)
Temperature 2 56°C (132°F) [0x38] (TMPIN2)
Fan 0 1795 RPM [0x178] (FANIN0)
Fan PWM 0 99 pc [0x7F] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
Hardware monitor AMD ADL
Temperature 0 63°C (145°F) [0x3F] (TMPIN0)
let me know if u need more info...
the cpu doesnt go over 50c...
