Hello,
Im currently looking to upgrade my workstation and i cant decide between these two processors (i9-14900k and amd ryzen 9 7950x).
I am primarily looking for a processor most suitable for deep learning. I expect high ram usage and wish to have as much ram available as possible.
Furthermore i do not expect to upgrade very soon thus if it uses the lga 1700 or am5 is of no concern future proof wise.
I will primarily use my graphics card, the RTX 4090. However the processor should still be efficient at loading data.
i also expect to do a lot of offloading of parameters and data to memory. It is not meant for gaming.
It is difficult to make a good comparisons since most benchmarks are for gaming.
and any deep learning benchmarks are on the cpu only and not for dataloading or parameter offloading.
Thanks in advance for any advice!
