Question Advice/Double Check My Build
Jun 15, 2022
4
First off, I’m sorry to be adding to the amount of build help threads. Secondly, I haven’t build or had a PC for a minute. So that being said I feel like I’ve been missing out on a lot of good titles and content, especially on Steam. I started looking around and saw a post by Danny Choo. His gaming PC was featured in the post and I thought I’d like one too. I really liked the case most of all. I then quickly put together a little list of parts, but I’m absolutely unsure if it would all work together and would have some possibility for upgrades in the future as system requirements ever increase.
So, I’m here hoping y’all lovely forum goers would lend me your expertise and recommendations on possible alterations if need be. Special considerations, I’m not overly interested in RBG lighting, so if you know any alternatives for the cooling fan and motherboard I would be grateful. And thank you for your time and any insight you can provide me.
Below follows the list over everything I think I need with Newegg links, and some questions related to said component.
Computer Case: XTIA Xproto case
https://xtia.design/products/xtia-xproto-1
Question: Would I need a “PCI-E Riser” and a A/O Bracket? If so which?
Motherboard: GIGABYTE B550I AORUS PRO AX AM4 AMD B550 Mini-ITX Motherboard with Dual M.2, SATA 6Gb/s, USB 3.2 Gen 1, WIFI 6, 2.5 GbE LAN, PCIe 4.0
https://www.newegg.com/gigabyte-b550i-aorus-pro-ax/p/N82E16813145222?Item=9SIB7RAH014036
Video Graphic Devices: GIGABYTE Gaming GeForce RTX 3080 Ti 12GB GDDR6X PCI Express 4.0 ATX Video Card GV-N308TGAMING OC-12GD
https://www.newegg.com/gigabyte-gef...c-12gd/p/N82E16814932436?Item=N82E16814932436
Question: XTIA Xproto Case has GPU size compatibility considerations. Would this GPU work?
CPU/Processor: AMD Ryzen 5 3rd Gen - RYZEN 5 3600 Matisse (Zen 2) 6-Core 3.6 GHz (4.2 GHz Max Boost) Socket AM4 65W 100-100000031BOX Desktop Processor
https://www.newegg.com/amd-ryzen-5-3600/p/N82E16819113569?Item=9SIASGMDH84496
Memory: CORSAIR Vengeance LPX 64GB (2 x 32GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel XMP 2.0 Desktop Memory Model CMK64GX4M2E3200C16
https://www.newegg.com/corsair-64gb-288-pin-ddr4-sdram/p/N82E16820236586?Item=9SIB7BAGW16637
Storage: Crucial P5 Plus M.2 2280 1TB PCI-Express 4.0 x4 NVMe 3D NAND Internal Solid State Drive (SSD) CT1000P5PSSD8
https://www.newegg.com/crucial-1tb-p5-plus/p/N82E16820156280?Item=9SIB8YMH2M1159
Power Supply: CORSAIR SF750 CP-9020186-NA 750 W SFX 80 PLUS PLATINUM Certified Full Modular Power Supply
https://www.newegg.com/corsair-sf75...817139080?Item=N82E16817139080&quicklink=true
Question: Is this adequately sized?
PC Cooling: Cooler Master MasterAir G100M CPU Cooling System with RGB Controller (MAM-G1CN-924PC-R1)
https://www.newegg.com/p/13C-000X-00451?Item=9SIAKVHGSY5261
Straight away I am going to mention to you to consider moving up to a 5600X or better. In the case that you do you will need to be sure that your motherboard supports it out of the box, or if it will need a BIOS update to be compatible. This is the fun inherent in selecting from AMD's offerings today. Don't get me wrong, AM4 has been a great platform overall, but some of this compatibility quagmire is a bit of a PITA for the end user.
It's probably just me, but I would suggest a higher wattage PSU. The unit you picked is of good quality but also of the minimum suggested wattage for the 3080 ti.
The cooler is absolutely not going to be better than a Wraith flavor.
edit- if the board isn't compatible out of the box with the 5xxx, there are boards that allow you to flash from USB without components. I did not look to see if the selection you made is among those.
https://www.newegg.com/super-flower-leadex-iii-sf-850f14hg-850w/p/1HU-024C-00005
Super Flower Leadex III 850W 80+ Gold Modular Power Supply $109.99 + $5 off w/ promo code FDYBTA4357
https://www.newegg.com/p/N82E16813145396
GIGABYTE Z690I AORUS ULTRA LITE DDR4 $149.99
https://www.gigabyte.com/Motherboard/Z690I-AORUS-ULTRA-LITE-DDR4-rev-10#kf
https://www.newegg.com/intel-core-i5-12400f-core-i5-12th-gen/p/N82E16819118360
Intel Core i5-12400F $169.94
https://ark.intel.com/content/www/u...2400f-processor-18m-cache-up-to-4-40-ghz.html
i5 12400 / 12400F gaming benchmarks.
Reactions: helper800
That all seems be a little more of a hassle than the plug and play I was hoping it would be. I guess I have a little tweaking to do.
A higher wattage PSU probably wouldn't hurt.
I'll have to look into Wraith coolers. Just from a quick Google; I kinda like the stealth variants.
Thanks for your input.
Links! I definitely might have to switch over to an intel CPU and that motherboard might work a little better for my needs.
Thanks for the recommendation.
Reactions: Why_Me
Your links total $2,150 + tax. What's your total budget?
What monitor do you have (or plan on getting)?
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($189.99 @ Amazon)
CPU Cooler: Deepcool AS500 70.81 CFM CPU Cooler ($50.00 @ Newegg)
Motherboard: ASRock B550 Phantom Gaming-ITX/ax Mini ITX AM4 Motherboard ($169.99 @ Newegg)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($114.99 @ Newegg)
Storage: Western Digital Black SN770 2 TB M.2-2280 NVME Solid State Drive ($199.99 @ Amazon)
Video Card: Asus GeForce RTX 3070 Ti 8 GB TUF GAMING OC Video Card ($718.50 @ Amazon)
Case: Fractal Design Torrent Nano Mini ITX Desktop Case ($134.98 @ Newegg)
Power Supply: EVGA SuperNOVA G6 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($89.99 @ Amazon)
Case Fan: Cooler Master MasterFan MF Halo 47.2 CFM 120 mm Fan ($18.98 @ Newegg)
Total: $1687.41
Generated by PCPartPicker 2022-06-16 10:47 EDT-0400
Total: $1687.41
I'd like not to spend too much, maybe $2,250.00, but I'll probably hunt around for the best price for new or look for used/second hand parts.
I have a LG 27UN880-B Ultrafine Monitor 27” right now that I use as a second monitor for my MacBook.
I hadn't found pcpartpicker.com before. Oh man! I could go broke building something with that.
It saves you money by pulling the cheapest sources of components. Some sales/coupon codes don't reflect in PCPP. Amazon pricing fluctuates by the minute, and newegg has sales flyers that come out pretty much every day, so make sure you give one final "manual" search before buying.
