Hello folks,
I was thinking about replacing my old i5 3470 desktop which I use for web development and light gaming (Battlefield 1 and Battlefield V multiplayer and thats it) with a new build. I went to the shop's site and the first list is the parts I've picked myself after reading the description (Bear with me I'm just a software guy; don't know much about hardware, but the description said they are compatible so went with it). After contacting the shop the shop said the second build (second list) is more performant than my parts.
MY INITIAL BUILD (UNDER MY BUDGET)
BUILD RECOMMENDED BY MY SHOP (BIT ABOVE BUDGET)
I really want some advice on how I can improve this situation, which one to go or maybe a change to a completely different part/parts. (I have a GPU; from the old build which I'm gonna transfer to a new build 😀). Sorry for saying "mid range" this could be low end af but I really don't know.
Thank you!
- Intel® Core™ i7-10700F
- ASUS PRIME H510M-E (MOBO)
- T-CREATE CLASSIC 10L 16GB (2 x 8GB) 3200Mhz
- Seagate BarraCuda 2TB ST2000DM005 (HDD)
- Antec VP550 PLUS 550W 80+ (Power Supply)
- GAMDIAS BOREAS M1-610 (Cooler)
- WD Green 120GB M.2 SSD
- INTEL CORE I5- 10400F
- ANTEC NEPTUNE 120 RGB (Liquid Cooler)
- MSI B460M BAZOOKA (MOBO)
- 2 X PATRIOT SPrem 8GB 3200Mhz
- CORSAIR CV550 80+BRONZE
- ADDLINK S20 SATA 256GB
- WD BLUE 2.0TB
Thank you!
