Advice on a workhorse desktop build for heavy in-memory work
indigene
5
I do analytical modelling. My work requires very heavy in-memory work. File storage, streaming, video acceleration are not critical for me. Not an always on system, but long hours with heavy computing spikes.
I am seeking configuration recommendations for such a desktop workhorse.
Please advice me on all components: RAM, motherboard, chipset/processor, hard drive, cooling, box, etc.
I am in India, will order most components online (amazon) and have kept my budget flexible but capped at ~ ₹100,000 (approx.$1560)
Singular most important tool is MS Excel with a few data analysis plugins: Solver, PowerPivot, Analysis Toolpak, etc.
Tableau Desktop
Chrome/TOR
Other office tools
I work on a dual-boot Windows 10 & (K)Ubuntu 16.04.
Thanks @King Dranzer
Have been working with 16Gb (2X8Gb) RAM on a i5-3450 @3.10Ghz - and even running Pivot tables on a million rows gets hung many times. I have more resource heavy tools like Solver.
Would a full utilization of 64GB (4X16GB DDR4) on some of the motherboards like the Z270/H270 be better for heavy computations?
Also, does an i7-7700 work better on a Z270/H270 or a B250M? Since you mentioned M, is the preference of microATX over ATX based on cost?
I have a couple of HDD from my old system (2TB+) and I wonder if I need a graphics card for the Excel work i do. Should I save on the expense on these two and instead put more on the atx and RAM?
If I do go for the Z270/H270 i7-7700 with a max RAM, will the Corsair be good enough to cool - specially during overclocking?
That should solve all your problems. 64GB RAM.
There is no big difference when you go from B250 to H270 but there is difference when you go from B250/H270 to Z270 that is the ability to overclock which you don't require. Besides that no big difference.
Same number of SATA 6GB/s ports. All support 64GB RAM.
A quad channel memory support with a more powerful cpu can maybe benefit ur work type
Cpu http://www.amazon.in/gp/aw/d/B01FJLAITC/ref=mp_s_a_1_1?ie=UTF8&qid=1502431208&sr=8-1&pi=AC_SX118_SY170_QL70&keywords=Intel+6850&dpPl=1&dpID=518PebG%2BkzL&ref=plSrch 35k
Mobo https://www.mdcomputers.in/intel-platform/asus-x99-m-ws-se.html 20k
Cooler http://www.amazon.in/gp/aw/d/B00G9YBHEY/ref=mp_s_a_1_8?ie=UTF8&qid=1502431376&sr=8-8&pi=AC_SX118_SY170_FMwebp_QL65&keywords=Mugen&dpPl=1&dpID=51EJkNgXRnL&ref=plSrch 6k
And I think you can salvage ur old ddr4 rams and add another 16gigs. U can also use ur case and hdd.
Add in the psu and ssd with the ram, cpu and mobo and u r done.
U have to set custom ram timings in bios since the 2 sets of 16gigs will be mismatched.
I don't think that extra cores will help. Please check the OP requirements and confirm it, and if possible short explanation will be good on how the more cores will improve performance.
Excel distributes computations over multi processors. I have a lot of computations in excel that tend to get 'volatile" at times. Does having more cores address this?
Also, sorry my bad about GPU - but it seems GPU is not necessarily for gaming/video but can also augment CPU for heavy computations, right?
both ur points depends on the softwares u use. like i said, u can set no. of cores to be used in ansys and quad channel memory helps too. as far as i know excel doesnt impliment multi channel work process. its pretty basic. but what abt ur plugins? do they have such options? its the same for gpu, ansys, sony vegas, and premier pro utilities nvidia cuda acceleration. do u have those options too?
Not only production work like premie pro vegas etc but even basic software like Publisher and Excel utilizes GPU to some extent to decrease the load on CPU. But depending on work OP does he does utilize more number of cores as his Excel distributes workload to multiple cores for continuous calculations and changes in database. For that he needs dedicated workstation with decent enough storage for big database entries and multiple cores(EPYC or Xeon) But trust me that would be overkill for any means of workload unless it is for business setup in which the setup is calculated under the capital investment and not the personal expenditure.(Don't know why I am going into economics consider it off topic)
For OP I would recommend the Ryzen R7 as it is personal build and is only possible option in his budget. X99 is costlier because of motherboard and suitable Xeon or i7 processor is lot costlier than Ryzen R7. EPYC and XEON v5 are bit far to launch. Waiting for them is not recommended.
about the gpu, u r partly true. not all softwares use gpu cores for calculations. ansys still doesnt support radeon gpu for calculations. and iirc, the older versions of vegas also supported only cuda acceleration. only the latest supports radeon cuz of opengl i think.
