Got a Corsair crystal 570x case (comes with 3 x SP120 RGB fans) and have got 3 additional SP120 fans for additional airflow. My Mobo is a Asus X470 Prime. Currently because I only have 3 chassis fan headers, I am using 3 x 2-way y splitters to provide the 3pin DC controlled power to the fans on the mobos 4 pin headers. My question is two part:
1) I am currently running the front 3 fans for intake, the top 2 fans for intake, and the rear fan for exhaust. My 2700x is using the stock wraith prism cooler, my GPU is a gigabyte RTX 2070 with 3 fans, I have a 4K avermedia capture card, and my PSU is fan down (drawing air from under case. Is this the best way to set my fans up?
2) my fan header splitters are a nasty mustard and ketchup style which is taking away from my build aesthetic, do you guys have any recommendations for nicer splitters? (Preferably white to match my theme) or, a better alternative than using y-splitters? I want the computer to control fan speed as needed for temperature management
Thanks so much!
Thanks so much!
