Advice on first gaming pc build.
Stephen Mulkey
22
I really have no need for the highest settings and probably won't play any higher than 1080p. Just want to be able to play games with a smooth frame rate and make them look decent. This is my list so far. I'm open to any suggestions, and I'm a noob to building gamin pcs (I have built some office systems) so any help or resources would be great. I want to be able to play games like GTA V, Assassins Creed. Stuff like that. Let me know what you think. Any suggested alternate parts would be great if you think I would get better performance or value. Shooting for around a $1000-$1200 build buying a couple parts at a time once i'm sure what i'm getting.
ASRock FATAL1TY Z97 KILLER Motherboard
Intel Core i5-4690K Processor
Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz
Corsair Graphite Series 760T Full Tower Windowed Case - Black
Cooler Master V650 - Compact 650W 80 PLUS Gold Modular PSU
NVIDIA GeForce GTX 750 Ti Video Card
For the TI you should go for the 750ti EVGA FTW edition as I have it and the fans are better than the other ones i've had. I also run a 3monitor setup which plays Arma 3 which is a very demanding game, but yes, your setup is fairly looking just like mine, except i have 3 750ti's
But i advice you to get this motherboard instead http://www.msi.com/product/mb/Z97S-SLI-Krait-Edition.html#hero-overview
Thank you for the excellent advice. I will be updating my list with your suggestions. Side note I originally intended to list this as a discussion and somehow double posted as a discussion and question.
I was planning on a SSD, but I know little about them other then they are fast. I'm not sure which are good brands or what a good value is for what capacity.
Well I know my Desktops.
