i need advice on modding a ASRock DESKMEET X300 Mini PC Barebone for use as a nas / giga-switch / vm build
my plan is to add a
AMD Ryzen 5 5600G
64gb of ram
SK Hynix Gold P31 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive for main os an vm's
2 x Seagate BarraCuda 5TB Hard Drive HDD – 2.5 Inch (ST5000LM000) to mount internal for raid back up of most vatial data
of the external 20gb
QNAP QXG-2G4T-I225 Quad-Port 2.5 GbE Network Expansion Card
1 x Yottamaster Aluminum Alloy 5 Bay 2.5/3.5 inch USB3.1 Type C External Hard Drive Enclosure SABRENT USB Type-C to Dual
3.5” SATA and RAID Docking Station DS-2BCR
with 2 x Seagate IronWolf Pro 10TB (ST10000NE000)
upgrade psu to sfx an cables
add 120mm aio vi external modding
something like this
1. whats the psu form factor an size , as id like to replace with a fully modular gold efficient psu
an custom cables by cablemods.
2. does anyone have any tear-down pix of the inside ?
3. does this take full size ddr4 ram
4. has anyone run truenas core or scale
5. does the mobo support a 5600g out-of-the-box with out firmware update
6. can i install a pci multi port Ethernet card an run truenas with router os in a vm an config some of the ports
as vlan's an leave the others as just normal lan ports, is this something i can do vi router os an from a vm in
truenas
https://www.newegg.com/asrock-deskmeet-x300w-b-bb-box-us/p/N82E16856158083
my plan is to add a
AMD Ryzen 5 5600G
64gb of ram
something like this
![moddef.jpg.29a60451ab2cac9c9ee2a1434688a30e.jpg](/proxy.php?image=https%3A%2F%2Flinustechtips.com%2Fuploads%2Fmonthly_2022_11%2Fmoddef.jpg.29a60451ab2cac9c9ee2a1434688a30e.jpg&hash=c2ded62eb0f1cf11fe3b93fe4d9e0a19)
truenas
