[SOLVED] Advice on Motherboard, CPU, RAM, Graphics Card (Case and Power Supply Covered)
Dragonsbane11
45
Thank anyone in advance that gives me some tips on this!
Approximate Purchase Date: Next Two to Three months, (Tax return time) I know this makes pricing harder, but I would appreciate the suggestions for the build.
Budget Range: 600-1000
System Usage from Most to Least Important: Gaming, moving to VR, general office work, some light 3d modeling
Are you buying a monitor: Yes
Parts to Upgrade: CPU, Motherboard, Ram, Graphics Card, Storage, I have a https://www.amazon.com/gp/product/B00IKDETOW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 EVGA SuperNOVA 750 G2, 80+ GOLD 750W I bought three years ago with my last build, so I expect to get a few more builds from it.
Also my case is good I have a https://www.amazon.com/gp/product/B0093W1ERO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Coolermaster Scout 2
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg.com, Amazon.com (but open to others.)
Parts Preferences: AMD preferable, but I am not locked in.
Overclocking: Maybe
SLI or Crossfire: Maybe
Your Monitor Resolution:1920x1080 is my current, but looking back I have had this monitor for six years, so I would honestly love to get a recommendation on a upgrade with possibly keeping this monitor as a secondary for text messaging surfing etc...
Additional Comments: I do plan on using this PC for some remote play (SteamBox) but other than that my use case is what I stated above.
And Most Importantly, Why Are You Upgrading: Honestly my current PC works fine. But since I need to upgrade to Windows 10 anyway, I may as well get some new guts for my system. I have two SSDs (one is three years old, one is less than one, and a regular HD that is three years old, so I hope to reuse some of those with a possible purchase of a new boot drive.
Thank you all again for any assistance you can throw my way.
What are the capacities of the SSDs and HDDs?
https://pcpartpicker.com/list/DwBKhg Here's a list you can use if you reuse your drives. It also includes a full priced copy of windows.
Thanks for the reply, they are as follows. So at the oldest we are looking at 2016.
WD Blue 1TB PC Hard Drive - 7200 RPM Class, SATA 6 Gb/s, 64 MB Cache, 3.5"
SanDisk SSD PLUS 480GB Internal SSD - SATA III 6 Gb/s, 2.5 Inch /7mm, Up to 535 MB/s - SDSSDA-480G-G26 (Newest)
Samsung SSD 850 Evo 500gb
