[SOLVED] Advice on my PC build
Nov 22, 2020
5
Good day. I am an absolute beginner to building PCs and I am attempting to do just that. Could you give some advice on my build?
CPU : i5 10400-f
Ram : corsair vengeance lpx 8g (x2)
SSD : WD Blue 480GB
Motherboard : MSI MPG Z490 GAMING PLUS
GPU : RX 5600 XT
PSU : CORSAIR VS 450W 80PLUS
Thank you in advance.
Since you can not overclock the i5-10400, there is no need for a more expensive Z490 motherboard. Any lga1200 motherboard will do the job.
If, however you anticipate a upgrade to a K suffix processor like the i5-10600K in the future then a Z490 would be appropriate.
Buy only a top quality power supply.
Your psu is tier 5/6 on this list.
500w is about right, but
I have no problem overprovisioning a PSU a bit. Say 20%.
It will allow for a stronger future graphics card upgrade.
It will run cooler, quieter, and more efficiently in the middle third of it's range.
A PSU will only use the wattage demanded of it, regardless of it's max capability.
Consider a quality psu as a...
Consider a quality psu as a long term investment.
It can support several upgrades in the future since a power supply does not go obsolete quickly.
You will pay more, but consider a 650/750w seasonic focus with a 7/10 year warranty.
Here is a 650w unit with a 10 year warranty:
https://www.newegg.com/seasonic-focus-plus-650-gold-ssr-650fx-650w/p/N82E16817151186
The 750w version is only $10 more.
https://pcpartpicker.com/list/TMTZQD
Could you check if I got that right?
Latest posts
