Question Advice on upgrading graphics card is enough for gaming or not
Aug 8, 2024
I want to upgrade my normal PC to a gaming PC, but my budget is low. I was thinking, can I just change the graphics card to make it suitable for gaming? Also, could you suggest some good budget-friendly graphics cards that would work well for gaming?
Eximo
Ambassador
Not enough information to make any recommendations.
What PC do you have?
What is your current graphics card?
What is your current power supply? What PCIe power cables are available?
What games are you playing?
What resolution and settings are you looking for?
What is your budget?
