Hello,
I'd like peoples advice on this build for VR gaming. With some of the highest requirements for some games being a i7 9700K, NVIDIA RTX 2080 along with 16gb Ram.
The rig I'm working on is
AMD Ryzen 5 5600X
Sapphire Radeon RX 6700 XT MBA 12GB GDDR6 PCI-Express
Kingston HyperX Fury 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz Dual Channel
MSI B550 Micro ATX Motherboard
AMD CPU Cooler
600W 80Plus Bronze Rated PSU
all within a Kolink Citadel Glass SE ARGB Micro-ATX Gaming Case
Thank you for any advice. A RX 6700 is lower against a RTX 2080 but it's all within budget.
Alternatives are
Ryzen 7 3700X Eight Core 4.4GHz
Kingston HyperX Fury RGB 16GB (Because you've got to have that RGB!)
GeForce RTX 2060 OC Rev2 6144MB GDDR6
Could do with a better CPU and GPU I'm thinking. Not sure though.
I could go with
i9-9900K 3.6GHz (Coffee Lake)
Vulcan Z T-Force 32GB DDR4
and the same GPU RTX 2060 OC Rev2 6144MB GDDR6
Should I keep going or go in for the buy?
AMD Ryzen 5 5600X
AMD CPU Cooler
Alternatives are
I could go with
