Hello, I had the motherboard MSI B75MA-E33, but unfortunately it had a problem and I had to replace it, I bought this recently: https://www.aliexpress.com/item/Free-Shipping-Motherboard-RS232-DB9-Pin-Com-Port-Ribbon-Serial-Cable-Connector-Bracket/32594501769.html? as I wanted to add a serial port in my PC for some reasons.
The new motherboard I got is Gigabyte GA-B75M-D2V which doesn't seem to have a JCOM1/other serial port connector that will fit what I purchased. My questions are:
1.Is it possible that I'm wrong? I checked the manual and also looked at pictures, it doesn't seem to have JCOM1/serial port/anything else that should fit, at least not as far as I'm aware(I don't think USB port should work?)
2.What can I do? I can maybe order something like this: https://www.aliexpress.com/item/PCI-E-serial-card-pcie-to-serial-RS232-interface-industrial-expansion-card/32785578737.html? but I don't really feel like spending 10$ on another one like this, is there maybe any adapter I can use? Or any other idea? Thanks
